mrosen
Jan 01, 2021Tutor
AX5400 Modem Requirements
I am considering this router but I'm confused as to whether or not I need a modem with a 2.5 Gbps ethernet port. While shopping for cable modems, I see there are modems offering this and those that ...
Newfiedrool
Jan 01, 2021Virtuoso
That's all you will get so a 2.5 port would not get you anymore than 600Mbps.
I'm guessing you are US where I'm U.K. so I don't know all the various types available but I'm sure if you posted some a helpful person will help out.
Newfiedrool
Jan 02, 2021Virtuoso
I'm also bit confused as I'm not sure the router you are looking has 2.5 connection. What's the model you are looking at?
