ReachAMR
Feb 12, 2022Aspirant
Re: AX80 AX600 To Work needs to be rebooted 2 or more times daily (Otherwise Incorrect Wifi Password
I am not in IT so please keep it simple - thank you. I purchased this router a year ago and for the last several months, when I go to access the internet whatever device I am using will say th...
ReachAMR
Feb 13, 2022Aspirant
- Hardware Version
1.01
Firmware Version
V2.1.3.5
Cable Firmware Version
V1.02.08
- There is none - This Cable Modem Router is using ISP COMACST coaxial cable
How is the routers WiFi SSID name and password configured? WPA2 and AES only?
- WPA2-PSK (AES) [I did not secelct this so I think is is defualt]
What devices are you trying to connect? If any Apple devices, disable WiFi Private Address feature on these devices.
- Yes, I have phone and tablet - this featrue was turned on and it is now disabled.
ReachAMR
Feb 15, 2022Aspirant
Disableling the WiFi Private Address feature on Apple devices did not resolve the issue. Is there anyting in the log that will indicate a reason as to why the router is not working as desinged?
