ReachAMR
Feb 12, 2022Aspirant
Re: AX80 AX600 To Work needs to be rebooted 2 or more times daily (Otherwise Incorrect Wifi Password
I am not in IT so please keep it simple - thank you. I purchased this router a year ago and for the last several months, when I go to access the internet whatever device I am using will say th...
ReachAMR
Feb 16, 2022Aspirant
Thank you! When I reset the router back to defualt and setup a second time I changed the SSID names but used the same password. Would that cuase any issues? I have about 30 devices attached about 20 of them are WIFI wall and light switches. The rest are TVs, Computures, Moble devices Razor512
Razor512
Feb 16, 2022Prodigy
If the new SSID is different from others in range (e.g., not using the same SSID as a nearby neighbor) then that should be fine, and there will be no need for additional changes, especially since that would take a ton of work redoing the setup for the IOT devices to have them connect to a new SSID.
