ReachAMR
Feb 12, 2022Aspirant
Re: AX80 AX600 To Work needs to be rebooted 2 or more times daily (Otherwise Incorrect Wifi Password
I am not in IT so please keep it simple - thank you. I purchased this router a year ago and for the last several months, when I go to access the internet whatever device I am using will say th...
ReachAMR
Feb 17, 2022Aspirant
Nope the SSID names are not in use by anyone else in range. The router needing to be rebooted daily is still happening. Very frustating as it worked great for about a year. From from a Nighthawk to a Nightmare.
No Support and Comcast says its the router and if Netgear had custoemr support they would say it is Comcast. I have had Comcast for over 20 years and never had this ever happen before - sure it goes down but not mutliple reboots per day.
Hope someone else has same issue and found out the root cuase and will share.
esarhaddon
Feb 24, 2022Aspirant
Concerning when yo talk to Xfinity, they will always blame it on privately-owned equipment. I had two techs come out on consecutive days and prove it without a doubt on the first day it was the router at fault and showed the modem was fine, the next day the tech (brother to the first one) proved without a doubt it was the modems fault and how the router was fine. Yes there are ways of doing that. I have spent many hundreds of dollars chasing this and it was their lousy equipment all along and it turned out to be something totally dissasoiated from the INternet part of the system. It was the TV box that was injecting noise in the system.
