ReachAMR
Feb 12, 2022Aspirant
Re: AX80 AX600 To Work needs to be rebooted 2 or more times daily (Otherwise Incorrect Wifi Password
I am not in IT so please keep it simple - thank you. I purchased this router a year ago and for the last several months, when I go to access the internet whatever device I am using will say th...
Feb 24, 2022Guru - Experienced User
Enjoy. 📡
ReachAMR wrote:
Just following up - it has been six days and all is okay. Not sure why creating the guest network is working but it is. Just to be clear, I am not using the guest network, I just set it up. I made no other changes. I will update again if anything changes.
ReachAMR
Feb 27, 2022Aspirant
Razor512 FURRYe38 Sad, news the problem is back with the router stops working and has to be rebooted (three times in the past hour). I am going to try and reset the modem back to the prior firmware. If this does not work, I will destroy this modem and never return to Netgear - this is a horrabile business model. I appaud you guys for trying to help people for free.
- Razor512Feb 27, 2022Prodigy
If trying an older firmware, be sure to factory reset after downgrading, and also skip any firmware update, since during the initial setup wizard, it will check fir updates.
