BVDpa
Feb 01, 2020Aspirant
Change Device Connection Type
How do I change the connection type for a device that is connected to the wrong connection? I currently set up both 2.4 GHz and 5 GHz connections. When I originally set up my network I was able to ...
Feb 03, 2020Guru - Experienced User
This article walks you through it.
https://kb.netgear.com/23439/How-do-I-change-my-NETGEAR-router-s-WiFi-password-or-network-name-SSID
BVDpa
Feb 03, 2020Aspirant
Thanks but this article does not address my situation.
- plemansFeb 03, 2020Guru - Experienced User
Then I guess you need to better describe what you're trying to do so I understand it.
- BVDpaFeb 03, 2020Aspirant
Hi,
When I originally set up my home network with the RAX80 wireless router I set up both a 2.4 GHz and a 5 GHz connection option for my network and I originally manually assigned my devices to the appropriate speed network connection types. It was easy to do but now I want to change a couple connections and I cannot figure out how to change the connection type. Thanks for your patience and help.
By connection type do you mean for 2.4ghz to 5ghz?
if so, they need to have seperate ssids (names) to individualize.
That's the article I linked to.
If not, what do you mean by connection types
