4estOC
Jan 08, 2020Guide
CM1200 to Rax200 WAN aggregation slows down (requires reboot)
I have a CM1200 modem and RAX200 Router with WAN agreggation (2Gig). My internet speeds slow down to 25Mb after approx 24 hours. Rebooting the router fixes the issue for another 24 hours and then the...
jaxon5911
May 24, 2020Aspirant
I am having the same problem. Is there a work around or a firmware fix?
Thanks
nEo717
May 24, 2020Guide
Many times fastest is disconnect 1 wan cables from modem to router for 20 seconds or so and plug back in — I’ve been rebooting router when get slow down and that works very time.
I’ve asked support for at least an option to be added in firmware for daily reboot of RAX120.
My guess is that this will not get fixed and that new modems will start coming out with 2.5 and 5.0 gig single wan port vs WAN LAG — based upon all very latest routers from other brands already coming with multi-gig wan ports.
