PeteDog
Dec 16, 2020Star
Current RAX120 firmware version
The web site download page shows the current firmware version as 1.0.2.136. This morning I checked using the phone app, and it shows a version 1.2.0.16 available. Installed OK but want to verify th...
AVLTechDude
Dec 16, 2020Tutor
Christian_R any comment on the reports from multiple others that installing 1.2.0.16 breaks wired connections? Is there anything in the release notes about a change required after installation? I can't afford to install it and break wired connections and be unable to work tomorrow. Thank you.
avtella
Dec 16, 2020Prodigy
The new firmware on my RAX120 no longer lets me select United States for Wireless and only options are Australia/Europe/Korea/Hong Kong/Singapore.
