PeteDog
Dec 16, 2020Star
Current RAX120 firmware version
The web site download page shows the current firmware version as 1.0.2.136. This morning I checked using the phone app, and it shows a version 1.2.0.16 available. Installed OK but want to verify th...
Newfiedrool
Dec 19, 2020Virtuoso
MRGIZBO wrote:Same issue here (ES).
Router updated by itself (despite I had auto off) but still shows an update is available (because of the language package I guess).
I don't use wired ports but Wi-Fi speed became terrible in both 2.4 and 5 GHz.
I realized with a 2012 LG SmartTV.
New firmware seems to be also for new RAX120v2 and in my opinion is focused on this new v2 version.
Installing the old 1.0.2.136 works fine again. I will wait for the next version.
Did you reset the router after updating?
MRGIZBO
Dec 19, 2020Tutor
I did.
1.0.2.136 seems pretty good for now.
- NewfiedroolDec 20, 2020Virtuoso
MRGIZBO wrote:I did.
I'm having no issues to be honest, you may have only rebooted rather than reset which is using the rear pin hole method if you could confirm and confirm if you reset via the software rather than the pin hole.
if the auto update is not working as you said it was set to off I'm guessing it's updated again the next morning because a bug like that would not be a one off.
When it does reset the router and rather than test on a tv perhaps watch what's going on with a WiFi analyser and if you have a mobile device say an iPad Pro or iPhone there is an app called WiFi Sweetspots which is good at giving you an idea what internal throughput you are seeing on that device and if it's stable.
Run PingPlotter too and just double check what you see.
Would be interesting to see what results you are seeing.
