PeteDog
Dec 16, 2020Star
Current RAX120 firmware version
The web site download page shows the current firmware version as 1.0.2.136. This morning I checked using the phone app, and it shows a version 1.2.0.16 available. Installed OK but want to verify th...
Newfiedrool
Dec 21, 2020Virtuoso
soeun wrote:I downloaded it from https://www.netgear.com/support/product/RAX120.aspx#download and installed manually and also reset my rax120 and I'm still getting the same issues of none of my LAN connections being able to access internet. Everything connected via wifi still works. I'm usually quite patient but this is getting ridiculous.
Did you perform a software reset or the pinhole reset?
Crtfdgk
Dec 21, 2020Star
Would like to reiterate for the thread that I also have had issues with the LAN ports after an upgrade and full reset. I’ve tried resets through the web interface as well as the pinhole. I’ve tried downgrading (which immediately restored functionality), erasing again, upgrading and re-erasing a third time via the web interface. I’ve tried not using a settings backup and creating a minimal config - but nothing works.
The LAN ports do still ping out and I can actually use curl to pull down non-SSL websites. The issue seems to be that any secure connection is blocked by some internal service or firewall on the router. Here’s an example:
~ ❯❯❯ curl -v https://google.com
* Trying 172.217.14.238:443...
* Connected to google.com (172.217.14.238) port 443 (#0)
* ALPN, offering http/1.1
* Cipher selection: ALL:!EXPORT:!EXPORT40:!EXPORT56:!aNULL:!LOW:!RC4:@STRENGTH
* successfully set certificate verify locations:
* CAfile: /opt/chef-workstation/embedded/ssl/certs/cacert.pem
* CApath: none
* TLSv1.2 (OUT), TLS header, Certificate Status (22):
* TLSv1.2 (OUT), TLS handshake, Client hello (1):
* OpenSSL SSL_connect: SSL_ERROR_SYSCALL in connection to google.com:443
* Closing connection 0
curl: (35) OpenSSL SSL_connect: SSL_ERROR_SYSCALL in connection to google.com:443
The expected “Server Hello” inbound traffic never makes it, unless the client is on WiFi and then there’s no issue.
* CApath: none
- NewfiedroolDec 21, 2020Virtuoso
Could you try downloading the update via the support page and try install manually then performing a factory reset.
- CrtfdgkDec 21, 2020StarYep - all of my upgrades and downgrades (except for the very first one that was an auto-upgrade) have been done via the web interface and the .img downloaded from support.
What we did notice was when I compared mine to my friends there was a lot more memory used compared to his. I turned my router off for 15min as he did and that cleared the memory.
worth upgrading, reset, setup, turn off router and leave then turn on and see what happens.
- soeunDec 21, 2020ApprenticeMy exact issue. Thanks for filling in the extra details.
