PeteDog
Dec 16, 2020Star
Current RAX120 firmware version
The web site download page shows the current firmware version as 1.0.2.136. This morning I checked using the phone app, and it shows a version 1.2.0.16 available. Installed OK but want to verify th...
webder
Dec 22, 2020Star
I assumed nothing about you, you've contribute minimally to the thread and certainly nothing since I started reading.
Powering off versus powering off 'for 15 minutes' are two entirely different things and I made no such claim on the former. Powering off and even soft resetting in most cases (where firmware is appropriately configured) will zero logs and perform other beneficial functions, believing powering off for 15 minutes does anything contrary to this is ridiculous and I beg you go claim such to anyone with an electrical engineering degree.
Clearing NVRAM isn't even being discussed and this can be mitigated from within firmware.
Come on guys, all the rest of us are doing is highlighting a problem with the firmware and even discussing where it may lie. If you don't want to join the discussion that's fine, otherwise your solutions are somewhat rudimentory and non viable to the rest of us.
MRGIZBO
Dec 22, 2020Tutor
webder I agree, we are trying to find a solution and explaining our issues.
Kilo Do you think is better to create multiple support request instead of getting a global solution from Netgear once is obvious that there is a problem with more than 3 devices?
In this case, the brand should answer.
