PeteDog
Dec 16, 2020Star
Current RAX120 firmware version
The web site download page shows the current firmware version as 1.0.2.136. This morning I checked using the phone app, and it shows a version 1.2.0.16 available. Installed OK but want to verify th...
soeun
Mar 29, 2021Apprentice
I still get prompted for the update. They haven't pulled this firmware and doesn't look like they will. Still waiting for the next one. Don't think i'll be sticking with netgear when my next upgrade comes around.
Crtfdgk
Mar 29, 2021Star
I checked and I’m now being prompted to update again - seems like it was only temporarily unavailable.
- webderApr 03, 2021Star
I'm still in the same situation as you, Crtfdgk. Unable to make 1.2.0.16 play nicely in any way with wired LAN devices and wireless oddities that cause pages not to load. Best guess would be a misconfig of iptables or perhaps a bug in the version/package they're using, but that's an absolute shot in the dark. I check back weekly for a new version or even a response/acknowledgement from Netgear on the forums, not to mention the dead end of attemtping to raise the issue via support.
Still find it pretty appalling from what is meant to be a top end consumer product. Not having a go at any of the kind people that have offered troubleshooting advice, but factory resets are not going to solve this one for those of us experiencing issues. Hopefully Netgear come through with an update soon, but my opinion of Netgear has beyond regressed at this point.
