Murby's avatar
Murby
Data Blackmail via Router Function?
I'm considering purchasing a NetGear AX5400 router, or maybe a similar model, but I have a question.   My current router is an ASUS unit that is comparable in technology to the AX5400.  My home net...
  • CrimpOn's avatar
    Apr 20, 2026
    Exactly.  WiFi is a separate decision from the Firewall/router.  Everything depends on the area that requires coverage and the number/type of WiFi devices involved.
    Things get more complicated when the area is large enough to require some sort of mesh WiFi system.
