DearGeo
Dec 02, 2021Tutor
Drop connection
RAX200 Nighthawk keeps dropping wired connection. I have narrowed it down to my router. I have soft and hard reset, rebooted modem and yet it doesn’t work. Firmware is up to date. I thought it was my ...
Dec 05, 2021Guru - Experienced User
You can reach out to a forum moderator and see what your options are. Let them know what your experiencing...
Altsai
Dec 07, 2021NETGEAR Expert
seems like xbox issue?!
- FURRYe38Dec 07, 2021Guru - Experienced User
Would not be the first time...
- DearGeoDec 09, 2021TutorI’ve been down that route with Xbox, until they told me to unplug my Xbox and see if the problem continues. DEFINITELY CONTINUES, it’s not an Xbox issue they narrow it down to the router. Even when there’s no Xbox plugged in and completely unplugged I’m still getting the “disconnected from wired network” and shortly after “Connected to wired network”. I see the error right on my LG TV- I contacted LG, they stated it’s not an LG but router issue. Now what?
- DarrenMDec 09, 2021Sr. NETGEAR Moderator
What if you connect the xbox via a wireless connection does it drop?
DarrenM
- DearGeoDec 09, 2021TutorAt this point my Xbox isn’t the issue, I connected to an orbi router and it works flawlessly.
My TV looses signal as I stated above. No Xbox connected. - Eric35Dec 14, 2021GuideI really thought Nighthawk ax11000 did not have the buffering / drop issue.
I was going to buy RaX200 but now i don't know...
I am having this issue right now with my Amplifi Router.
