HornsManiac's avatar
HornsManiac
HELP my model RAX50 is only broadcasting guest network
This morning the only network I see is the Guest one. I already rebooted my modem and router, and that didn't help. The problem is I cannot access the router online because I can't connect to it. I w...
  • Razor512's avatar
    Nov 09, 2022
    Seems last night, there was a bug with the latest update with the RAX50 where for some users, it failed to retain all of the changed settings. While it is annoying with rare issues like this, it is best to do a factory reset and do a setup from scratch without using a backup config file.
