Th3-0n3
May 26, 2020Tutor
Help router keeps loosing connection, slow speed, stop giving access to internet.
Ok so I have a Nighthawk® AX12 RAX120 ever since I updated to the most recent version that is V1.0.1.122. After the update I decded to do a factory reset on the router. I started to have this pr...
DarkHoplite
May 27, 2020Tutor
The latest update has definately resulted in connection issues, for me I have to reboot the ax120 at least every 2 days.
Joi007
May 27, 2020Tutor
I have mine configured using Smart Connect for WiFi perhaps that may help? My RAX120 also would lose routing it when I first got it, but after I swapped the modem to the CM600 it stopped? Perhaps it was me reconfiguring the router to the new modem which cleared something? Or perhaps it just might had been a coincidence?
My best advice would be to just reset the modem and reinstall the firmware update. Perhaps that may clear it for you. Strange my RAX120 would also lose its routing, but now it has been running flawlessly. Best router I've ever had? Strange.
| Firmware Version | V1.0.1.122 |
- DarkHopliteMay 27, 2020Tutor
Thanks, I will deifnetly do a clean re-install. I do know its not just the wifi that loses internet but from the lan port as well.
I will do a re-install later tonight and get back with a result in a few days time.
thanks again!
- Joi007May 27, 2020Tutor
Please do.
I keep track of it using The Journal 8.
REBOOTED ROUTER Intentionally for the upgrade speed provision 400 MBs d/l 20 MBs up @ 11:30 am May 15, 2020
Forgive me but was is Journal 8
- Th3-0n3May 27, 2020Tutor
thanks again!
This is exatcly the problem im having will do that too. It got worse yesturday. if this doesnt fix it ill donwgrade to the previous version and see if it works better on there.
