Th3-0n3
May 26, 2020Tutor
Help router keeps loosing connection, slow speed, stop giving access to internet.
Ok so I have a Nighthawk® AX12 RAX120 ever since I updated to the most recent version that is V1.0.1.122. After the update I decded to do a factory reset on the router. I started to have this pr...
DarkHoplite
May 27, 2020Tutor
Forgive me but was is Journal 8
Joi007
May 27, 2020Tutor
http://www.davidrm.com/tjdownload/
Just journaling software. That way I can easlily track what I do with the Router and what the router does.
This was entered there: This is the last time I rebooted the router, since I reprovisioned / upgraded to 400/20 from 200d/l 12 u/l and changed modem to CM600 no more loss of routing. Must had been a coencidendce.? The router is new for me I just got it in May.
Here is full log:
REBOOTED Nighthawk router at 11:00 a.m. lost “routing” May 7
REBOOTED Nighthawk router at 12:50 a.m. lost “routing” May 13
REBOOTED Nighthawk router intentionally for the upgrade speed provision 400 MBs d/l 20 MBs up @ 11:30 am May 15, 2020
After this I upgraded modem to CM600 since I was using a Spectrum CM to see if it would solve the routing issue and also while I was at it I upgraded speed. All that was done on May 15. NO more loss of routing. No reboot since May 15 per journal entry. Since May 15th it has functioned flawlessly???
I doubt it was the modem but other than the modem and line upgrade no other changes made? So what fixed it I don't know? The loss of routing just disappered right after that?
Netgerar RAX120 router.
