Erinpiper
Jan 05, 2022Star
Help with New Router
Hello, HELP. I think it's time to upgrade from my old WNDR3400V3 router. Should I consider a new router? I think I have 10 or so devices to connect. I have a small home 1400sq ft and co...
- Jan 05, 2022
Erinpiper wrote:
Are those options compatible with the new Nighthawk app? Is the app something to consider when looking at these new routers?
Will Netgear honor the renewed router as if it were new and does Netgear do the renew on the unit? I have never tried anything that was renewed?
Thank You
Renewed warranties are shorter as well as the support period is less. But even if you factor in an aftermarket warranty through amazon, its still far cheaper. And its just a thought. If its concerning and you'd like a longer support period, then go with a new device. but you'll end up with a lower spec device for the same price.
In terms of 6E, its not really in the budget for what you're plans are. And I'm not a huge fan of it yet as there really isn't much for 6e devices and its range is much shorter than 2.4ghz/5ghz.
With the devices you have, a decent dual band router should be more than enough. Tribands are nice when you get a lot of devices streaming at once. Your internet connection will bottleneck before the router will with what you're current speeds are.
And I'd certainly recommend making sure you have at least gigabit. 100mbps might be your speeds now, but a lot of the isp's have been setting their base speeds at that 200mbps speeds.
Jan 05, 2022Guru - Experienced User
Thank You
Erinpiper
Jan 14, 2022Star
Took your suggestion and found a renewed RAX80 router for $200 with 2 year warranty. Will post on ease of install and how it works.
Thank You
Thank You
- FURRYe38Jan 14, 2022Guru - Experienced User
https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-router - plemansJan 14, 2022Guru - Experienced User
Hope it works well for you!
- ErinpiperJan 18, 2022Star
I received the router today. Went to download the Nighthawk app and it says the app is not compatible with this device.
Is there another app or a way around this? I was really hoping this would work like the Net Genie did.
- michaelkenwardJan 18, 2022Guru - Experienced User
Was that the second-hand RAX80 mentioned a few messages ago?
The Nighthawk app supports it.
Which products support the NETGEAR Nighthawk app? | Answer | NETGEAR Support
Two possibilities I can think of:
- you need to factory reset the thing to wipe put inherited settings
- the seller dumped it because it has a problem
Then again, where did you try to download the app? And which version is it? (Android or iOS?)
More details from you could help to pin down the problem. For example, what told you that "the app is not compatible with this device"?
