Darkatt
Sep 07, 2026Aspirant
I have an raxe300 connected to a cm3000
I have an raxe300 connected to a cm3000, and it says the internet speed is 470 mbps, when the computer is connected direct to the cm3000 it says the internet speed is 1149mbps. If I try to manually s...
Darkatt
Sep 08, 2026Aspirant
The router to modem speed test on the router, was just under 450 mbps, the computer to the modem was 1149 mbps.
Router says Internet speed is 443 this last test, COMPUTER to modem says 1147 this time. Computer through router with MANUAL speed selected of 1000 mbps is 880 last test. 1000 is the MAXIMUM speed the router will allow me to enter.
Sep 08, 2026Guru - Experienced User
Router speed test may not be most accurate. Maybe picking not a best speed test site.
Yes 1000Mbps will be max since LAN ports on the RAXE are max 1000Mpbs. Nothing higher past this will be seen even though your using the MG port with the CM3000.
You might see over 1000mpbs with a 4x4 MIMO wifi devices connected at 5 or 6Ghz. When I had my RAXE500 online, I had a 4x4 MIMO wifi device online and got near 1000Mpbs on my ISP service. Only see just over 900Mpbs on a ethernet connected PC connected to the LAN ports is all. QOS disabled.
- DarkattSep 08, 2026Aspirant
I know all that. all I want to do is MANUALLY setup my internet bandwidth, and the max speed it allows is 1000 mbps, and my actual bandwidth is 1150 mbps.
- FURRYe38Sep 08, 2026Guru - Experienced User
And that's due to the 1Gb WAN and LAN ports. Nothing you can do about that.
