Darkatt
Sep 07, 2026Aspirant
I have an raxe300 connected to a cm3000
I have an raxe300 connected to a cm3000, and it says the internet speed is 470 mbps, when the computer is connected direct to the cm3000 it says the internet speed is 1149mbps. If I try to manually s...
Darkatt
Sep 08, 2026Aspirant
Throughput. I am unable to maximize my internet throughput due to the fact that it's internally limiting it. Even my wifi 6 devices top out at 880 mbps. My ethernet, and I have tried cat5e, cat6, cat7, and all perform exactly the same.
Sep 08, 2026Guru - Experienced User
Connected my RAXE500 behind a primary router to see what the speed test would report:
Connected my RAXE500 to my CM3000 modem:
Of course, I tried to set the I want to define my Internet Bandswidth to something higher than 1000Mpbs. I tried 1200 and wouldn't take. I set 1000Mpbs and it kept this setting.
What I get with speedtest app:
