RDPH
Feb 19, 2024Aspirant
Re-Installing Backed-Up CFG File
First off, please advise if this is the proper group to post things about an RAX48 AX5200 router. I think it is. Second, I want to try to eliminate some potential issues that I'm seeing with the ...
- Feb 19, 2024Yes, restoring a config file can re-introduce previous issues you had. Make sure a clean config by reconfiguring from scratch. Doing a factory reset and then using a backup config file to restore defeats the purpose of factory reset
microchip8
Feb 19, 2024Master
