Jeffwb2u
May 09, 2026Aspirant
Invalid Firmware error
I have a Netgear RAX43v2 Router currently running Firmware version 1.1.3.18. I have tried several methods to update the router to a new firmware version, but no matter what I try it says that the Fi...
CrimpOn
May 09, 2026Guru - Experienced User
It would be very helpful if you can double check that after downloading version 1.1.6.38, you extracted the firmware image file RAX43v2-V1.1.6.38_2.1.34.chk and this is the file that is what is being used for the manual firmware update.
- Jeffwb2uMay 11, 2026Aspirant
The Advanced upload page will only let you upload a file with the .CHK extension.
What I really wish is that Netgear would post MD5 Hashes of the files so that they could be checked for corruption in transit, (or even corruption in place if Netgear delivery channels are ever hacked). Without a hash of the file, there is no way beyond looking at the byte size to know if the file has been changed in any way.
I also wonder why they used .CHK as the extension as it is a commonly used file extension used with Chkdsk and ScanDisk.
- FURRYe38May 11, 2026Guru - Experienced User
Try changing the .chk to .img.
