Artisan54
Oct 13, 2024Aspirant
Re: iphones will not download apps or updates on wi-fi.
Hello, I'm experiencing this I have a NightHawk RAX54 Firmware Version V1.0.16.132_2.0.92 this started happening 4 days ago. I have factory reset the router and set everything back up. It's ...
- Oct 14, 2024
Try using other DNS besides ISP DNS, try Cloudfare or Quad9. After inputting and saving the configuration and apply, I'd do a full reboot of the ISP modem and router then try again on the phone.
Oct 14, 2024Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Is the router using auto detected ISP DNS or custom DNS? Try custom DNS like cloudfare or quad9 on the router.
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Nighthawk-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220015/jump-to/first-unread-message
- Artisan54Oct 14, 2024Aspirant
modem is an Arris surfboard SB6183
ISP and DNS is set to get from provider and the MAC address is set to default.
- FURRYe38Oct 14, 2024Guru - Experienced User
Try the suggestions to see if this helps any.
so I went to settings and set "private Wi-Fi address and" Limit IP address Tracking" to off. Then restarted the phone for good measure.
the only thing that changed is the phone is giving a privacy warning on the wifi connection but still unable to upgrade or download apps.
I switched from dynamic DNS to what Spectrum states is the primary and secondary setting. The IP address is still set to get from ISP as spectrum states that is dynamic.
