sudo-visudo
Apr 26, 2024Aspirant
Re: ipV6 disconnecting
My RAXE500 keeps dropping IPV6 connectivity. After a few days when you check using whatismyipaddress.com, the site reports no ipv6 connectivity at all. If you go into the router's ipv6 settings, "Rou...
sudo-visudo
Apr 29, 2024Aspirant
Thanks for replying.
I'm using the latest firmware, i.e., V1.2.13.100_2.0.54. My ISP is Google Fiber. Their fiber jack is on the wall, I don't know it's model number. It works OK.
I'm using a Cat6 cable. Google says I can get away with Cat 5E. It's on the WAN port. connected directly to the fiber jack. They promise 1000-Mbps up and down. When check with LAN I consistently get 945-Mbps up/down, so they deliver.
Router settings for IPV6 are set to auto-config. In my experience no other setting works. I have Cloudflare's DNS servers on the router for both IPV4 and IPV6. They work great and are very fast.
When IPV6 disappears in it's all my devices. So far it's been 48 hours since my last reboot and IPV6 is still there.
Apr 29, 2024Guru - Experienced User
Ok. Might save off a back up config to file for safe keeping. Saves time if a reset is needed.
