sudo-visudo
Apr 26, 2024Aspirant
Re: ipV6 disconnecting
My RAXE500 keeps dropping IPV6 connectivity. After a few days when you check using whatismyipaddress.com, the site reports no ipv6 connectivity at all. If you go into the router's ipv6 settings, "Rou...
sudo-visudo
Apr 29, 2024Aspirant
"Fiber jack" is what Google calls their modems (device between fiber optic cable and router). They installed a model GFLT300. They fully support IPV6 and keep saying the problem is on my end. This makes sense when you reboot the router and IPV6 immediately comes back. I just checked and IPV6 is active. No reboot needed at this time.
The only way to get IPV6 to work on this router is to use auto-config. All other methods don't work.
With respect to the DNS servers on the router, none are perfect. Do you recommend switching back to the ISP's servers instead? I keep hearing Google is notorious for spying on everybody. Will using Cloudflare's (or anyone else's) servers help in any way?
Apr 29, 2024Guru - Experienced User
You can try any custom IPv6 DNS service. Try Cloudfare or Quad9 and see if the problem continues.
