sudo-visudo
Apr 26, 2024Aspirant
Re: ipV6 disconnecting
My RAXE500 keeps dropping IPV6 connectivity. After a few days when you check using whatismyipaddress.com, the site reports no ipv6 connectivity at all. If you go into the router's ipv6 settings, "Rou...
May 28, 2024Guru - Experienced User
Any progress on this?
sudo-visudo wrote:
My RAXE500 keeps dropping IPV6 connectivity. After a few days when you check using whatismyipaddress.com, the site reports no ipv6 connectivity at all. If you go into the router's ipv6 settings, "Router's IPV6 Address on LAN" is empty. This is NOT the case when IPV6 is active.
When you unplug the router for about 30 seconds and plug it back in, everything is back to normal. That is, for a few more days and you have to repeat the procedure in order to get IPV6 back. Clearly this is not an ISP issue, otherwise you could reboot the router many times and not get IPV6.
Is this a known issue or is there something weird going on here?
