wildwestman
Feb 25, 2024Guide
Is the RAXE300 considered a dead product?
So as the title says, is the RAXE300 dead? I mean there has been no firmware update for that device since almost a year, with critical bugs unfixed, like the known slow WiFi USB write speed, which i...
Feb 25, 2024Guru - Experienced User
Not that we know of.
Are you having problems with yours?
wildwestman
Feb 25, 2024Guide
Yes, the unfixed slow WiFi USB write speeds which is known since release but not fixed until now, the internet connection stopping working when only the modem is reset but not the router which is also there since day without any fix until now and the missing fixes for security vulnerabilities which other netgear routers regularly get.
At this point it feels like the support for the raxe300 is dropped and the router reached already it's end of life, without even fixing known issues.
