Joi007's avatar
Joi007
Tutor
May 12, 2020
Lost routing have to reboot router
Greetings,   I am running the latest firmware.  Router Firmware Version V1.0.1.122   On May 7th I had to reboot: REBOOTED Nighthawk router at 11:00 a.m. lost “routing”   On May 13 I had to re...
  • Joi007's avatar
    Joi007
    May 13, 2020
    Thank you for your response.  No sir I have not tried that yet.
    I'll monitor try a few things to see if I can find the actual cause and post the solution here for others.
    One other thing I was suspecting is DNS server. I could change it to Google DNS or Cloudflare DNS and see if that corrects the issue.
    Before I do any of the above I've ordered a [NETGEAR Cable Modem CM600 - Compatible with all Cable Providers including Xfinity by Comcast, Spectrum, Cox | For Cable Plans Up to 400 Mbps | DOCSIS 3.0].
    Currently I'm using a very old Ubee cable modem supplied by Spectrum.   Let's see if Netgear to Netgear plays a little nicer than Netgear to Ubee.
