JOSH15796
May 19, 2021Follower
RE: multi-gig internet (1Gbps + 1Gbps) setup on RAX 200
Folks, need your advice and expertise. Just subscribed to a broadband service (2 x 1000M) and wanted to aggregate the two ports. I followed the settings as per user manual but after several r...
May 19, 2021Guru - Experienced User
Both the modem and the router have to support port aggregation. I've haven't found any info that shows that modem supports port aggregation. I've actually ran into this issue a year ago with someone else. I researched it more and still don't see any info on it. I'd be betting it doesn't because your isp doesn't know anything about it and usually its an advertised feature.
https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/RAX200-Wan-Aggregation/m-p/1915494
