coyote3
Sep 15, 2019Guide
Multi-Gig port to PC?
Can I connect via the RAX120's Multi-Gig port (5G/2.G/1G) to a PC, with say a 5G ethernet port, and get 5G?
- Sep 16, 2019Yes, it can be used as a LAN port.
avtella
Sep 16, 2019Prodigy
It’s only a WAN (Internet side) port if you specifically select the 5gb port as WAN in internet settings, otherwise it acts as a LAN port. I have it connected to a 10Gbps switch (at 5Gbps link rate) which is connected to my NAS.
coyote3
Sep 16, 2019Guide
Very good to know, thanks!
Now the documentation (of it's default functionality) seems right after all.
