jimlenz
Apr 13, 2019Aspirant
Netgear AX12 and CM1100 Port Aggregation
Hello,
I just received my new AX12 and so far find it an excellent upgrade. I also have the CM11100 modem and see that both have Ethernet Port Aggregation. I have 1 gig service with comcast. ...
- Apr 14, 2019
I'll dumb it down a bit more for you.
Running a speed test, on a single device, directly connected to your RAX120 can only yield a max speed throughput of ~960Mbps (1Gbps minus overhead).
Running another speed test, on another device, at the same time, directly connected to your RAX120, can yet again, only yield a max speed throughput of ~960Mbps (again 1Gbps minus overhead).
Add the two results together and you should at least achieve 1000Mbps (full 1Gbps Internet connection). If your Internet has been over provisioned, you could see aggregated (pun intended) speeds in excess of 1Gbps. I would expect you'd achieve 1100-1200Mbps.
No matter the results above, if LACP LAG has been optimally implemented in both the RAX120 and CM1100, I'd continue to use LAG between them. You never know if your ISP overprovisions in the future, LAG provides load balancing, failover, etc, etc, etc.
Hopes this helps.
kc6108
Apr 18, 2019Luminary
Have you run any concurrent speed tests? You should achieve at least 1000 Mbps, but I'd imagine more like 1200 Mbps. You need to run a speed test on two fast devices though... like two laptops/PCs/etc.
Who is your ISP?
jimlenz
Apr 18, 2019Aspirant
I only ran on one, my iMac and got 911mb. I have Comcast and was hoping for faster. Not sure why.
- kc6108Apr 18, 2019Luminary
It's not going to happen. ~940 Mbps is the max speed you can achieve over a single gigabit port. LAG provides failover, load balancing, etc, but it doesn't automagically combine the ports into one big pipe.
Run two speed tests concurrently and see what you're really able to get from your connection :smileywink:
Run a speed test on your phone using the Speedtest app. Actually, do the same on your iMac. Get the Speedtest app from the macOS App Store. The apps run much more smoothly, and achieve higher throughput, than when running speed tests in the browser.
- jimlenzApr 18, 2019Aspirant
I got 831mb on my imac and 95 mb on my ipad(through wifi). similar numbers to when I run thte imac by itself. Not sure I see the benefit with wan aggregation connected.
- plemansApr 18, 2019Guru - Experienced User
My area doesn't have over provisioning on 1gig service. I max out at 940-950 (total download over 2 hardwired devices) whether or not I'm using link aggregation. Doesn't mean they won't in the future but they aren't currently.
Comcast doesn’t over provision either.
