jimlenz
Apr 13, 2019Aspirant
Netgear AX12 and CM1100 Port Aggregation
Hello,
I just received my new AX12 and so far find it an excellent upgrade. I also have the CM11100 modem and see that both have Ethernet Port Aggregation. I have 1 gig service with comcast. ...
- Apr 14, 2019
I'll dumb it down a bit more for you.
Running a speed test, on a single device, directly connected to your RAX120 can only yield a max speed throughput of ~960Mbps (1Gbps minus overhead).
Running another speed test, on another device, at the same time, directly connected to your RAX120, can yet again, only yield a max speed throughput of ~960Mbps (again 1Gbps minus overhead).
Add the two results together and you should at least achieve 1000Mbps (full 1Gbps Internet connection). If your Internet has been over provisioned, you could see aggregated (pun intended) speeds in excess of 1Gbps. I would expect you'd achieve 1100-1200Mbps.
No matter the results above, if LACP LAG has been optimally implemented in both the RAX120 and CM1100, I'd continue to use LAG between them. You never know if your ISP overprovisions in the future, LAG provides load balancing, failover, etc, etc, etc.
Hopes this helps.
jimlenz
May 04, 2019Aspirant
I tried to edit the post but could not. I think the router mlulti gig should go to 7 or 8 which are 5g, not 9 as that is 10g. Is this correct.
Also, router to modem, no change.
jimlenz
Last piece, setup the LAG on switch
Under LAG configuration it shows
Ch. 1 QNAP Enable, Enable, LACP, Down
When I go to LAG Membership it shows LAG 1 with 1, 2,3 and 4 checked.
Is there anything else needed?
- kc6108May 04, 2019Luminary
That is correct, use port 7 or 8 on the MS510TX.
It looks like you setup the LAG correctly:
chose a LAG (for example ch1) and changed it to LACP
added ports 1-4 on the MS510TX as members to ch1 LAG
If that's not working then maybe you missed a setting on the NAS to enable LACP LAG?
Sorry, this is all I can help with as I'm not familiar with QNAP NAS's... only Synology NAS's.
- schumakuMay 04, 2019Guru - Experienced User
Very similar - things need to be configured accordingly.
kc6108 wrote:
Anyone familiar with setting up an LACP LAG between a QNAP NAS and Netgear switch? schumaku maybe?
That might be a good guess 8-)
Let's see if jimlenz confirms the LACP 802.3d LACP config on the four NAS GbE ports to start with. Can bring up a TVS-473 with a four port LAG on a MS510TX if required for a test.
- jimlenzMay 04, 2019Aspirant
I went into the NAS and setup port trunking with the 4 lan spots. Once I rebooted, the NAS runs very slow and when I reboot it takes forever. Obviously, something is wrong with the setup either from the NAS or switch side.
When it diid finally login I tried to get back to the network section of control panel to change things back but it continues to say it is loading and wait.
When I connect the Lan cables to the switch do they have to line up 1 to 1, 2 to 2 and so forth? If so, that may be a problem but cant imagine it would be.
I utilized these instructions to setup.
When I reboot and go into qfinder pro it says the NAS has entered an abnormal state and says to contact the system administrator. I can never get to the login page. Definitely something is wrong.
Any advice is helpful.
I tried to disconnect the other lan cables and onlly have #1 but continue to have the same problem. When I disconnect from the switch and connect back into my router, everything is back to normal.
Sequence doesn't matter.
Operating a Virtual Switch or four native interfaces with the Port Trunking on QTS?
I would opt for an LACP (803.3ad) trunk - obviously on both ends - instead of going for a static LAG with balanced-xor policy.
This reads similar to the problems we're experiencing with the LAG on the two 10G ports.
Quickly set-up an LACP LAG over the four GbE ports g1..g4 on the MS510TX and the four GbE ports on a TVS-473:
[~] # cat /proc/net/bonding/bond*
Ethernet Channel Bonding Driver: v3.7.1 (April 27, 2011)Bonding Mode: IEEE 802.3ad Dynamic link aggregation
Transmit Hash Policy: layer2+3 (2)
MII Status: up
MII Polling Interval (ms): 100
Up Delay (ms): 0
Down Delay (ms): 0802.3ad info
LACP rate: slow
Min links: 0
Aggregator selection policy (ad_select): stable
System priority: 65535
System MAC address: 24:5e:be:XX:XX.X2
Active Aggregator Info:
Aggregator ID: 4
Number of ports: 4
Actor Key: 9
Partner Key: 1000
Partner Mac Address: 10:XX:XX:XX:XX:55Slave Interface: eth0
MII Status: up
Speed: 1000 Mbps
Duplex: full
Link Failure Count: 0
Permanent HW addr: 24:5e:be:XX:XX.X2
Slave queue ID: 0
Aggregator ID: 4
Actor Churn State: none
Partner Churn State: none
Actor Churned Count: 0
Partner Churned Count: 0
details actor lacp pdu:
system priority: 65535
system mac address: 24:5e:be:XX:XX.X2
port key: 9
port priority: 255
port number: 1
port state: 61
details partner lacp pdu:
system priority: 32768
system mac address: 10:XX:XX:XX:XX:55
oper key: 1000
port priority: 128
port number: 1
port state: 61Slave Interface: eth1
MII Status: up
Speed: 1000 Mbps
Duplex: full
Permanent HW addr: 24:5e:be:XX:XX.X3
Slave queue ID: 0
Aggregator ID: 4
port key: 9
port priority: 255
port number: 2
port state: 61
oper key: 1000
port priority: 128
port number: 2
port state: 61Slave Interface: eth2
MII Status: up
Speed: 1000 Mbps
Duplex: full
Permanent HW addr: 24:5e:be:XX:XX.X4
Slave queue ID: 0
Aggregator ID: 4
port key: 9
port priority: 255
port number: 3
port state: 61
oper key: 1000
port priority: 128
port number: 3
port state: 61Slave Interface: eth3
MII Status: up
Speed: 1000 Mbps
Duplex: full
Permanent HW addr: 24:5e:be:XX:XX.X5
Slave queue ID: 0
Aggregator ID: 4
port key: 9
port priority: 255
port number: 4
port state: 61
oper key: 1000
port priority: 128
port number: 4
port state: 61
Ethernet Channel Bonding Driver: v3.7.1 (April 27, 2011)Looks OK to me.
04 May 2019 21:52:33 UTC+1:00%STP-W-PORTSTATUS: ch1 of instance 0: STP status Forwarding 04 May 2019 21:52:28 UTC+1:00%LINK-I-Up: ch1 04 May 2019 21:52:27 UTC+1:00%TRUNK-I-PORTADDED: Port g4 added to ch1 04 May 2019 21:52:27 UTC+1:00%TRUNK-I-PORTADDED: Port g3 added to ch1 04 May 2019 21:52:27 UTC+1:00%TRUNK-I-PORTADDED: Port g2 added to ch1 04 May 2019 21:52:27 UTC+1:00%TRUNK-I-PORTADDED: Port g1 added to ch1 04 May 2019 21:52:24 UTC+1:00%LINK-I-Up: g1 04 May 2019 21:52:23 UTC+1:00%LINK-I-Up: g2 04 May 2019 21:52:23 UTC+1:00%LINK-I-Up: g3 04 May 2019 21:52:22 UTC+1:00%LINK-I-Up: g4
