stockbucks
Jun 17, 2024Aspirant
Netgear R6700AX AX1800 Router won't connect wirelessly...ENET working fine thru Router
R6700AX firmware ver: 1.0.15.146......Win10 Pro H22022...Centurylink modem automatically updates firmware! My INET thru ENET in router thru Centurylink C4000LZ in Transparent Bridge Mode (VPI/VCI...
michaelkenward
Jun 18, 2024Guru - Experienced User
stockbucks wrote:
My INET thru ENET in router thru Centurylink C4000LZ in Transparent Bridge Mode (VPI/VCI = Untagged) working great...
Can you say a bit more about the "bridge mode"?
There is usually more to it that a simple tweak. For example, a lot of people turn up here thinking that turning off the wifi does the trick. No.
Then there is the problem that bridge mode means different things on different contexts.
Throw in how different modem/routers work and you enter a minefield.
In this case, how does "VPI/VCI = Untagged" fit into the bigger picture?
stockbucks
Jun 18, 2024Aspirant
Sorry about the quality, thx 🙂
