brad99superd
Feb 13, 2025Initiate
Re: NETGEAR_RAX43v2 will not update to this Version of firmware 1.1.4.28!
Hey guys, any updates to this? Support has been trying to get this firmware updated and no luck. We've tried a factory reset, updating manually. No prevail!!
Feb 17, 2025Guru - Experienced User
What is happening when you try to update the router?
How are you trying to update the router? Manually? Unpacking the .zip file?
What browser are you using? Try a different browser?
What FW version is currently loaded on the router?
brad99superd
Feb 17, 2025Initiate
Good questions thanks for your response!
What is happening when you try to update the router? It updated to the version previous, for the newest version it's saying that the firmware is not compatible with my router.
How are you trying to update the router? Manually? Unpacking the .zip file? Tried all of the above, same results, got a call in to Netgear.....support and I reset my router to factory reset and still same issue. They have tried updating it as well with their steps (in which are the same as I tried)
What browser are you using? Try a different browser? Edge and Chrome (we did both)
Firmware Update Assistant
I got a call back from the vendor, they believe it's an issue with the firmware, clearly most of us are having the issue. They are going to get back to me. (just an update)
Thanks for your response!
- CJ_LIUNov 17, 2025Aspirant
Hi brad99superd,
I just encountered the same issue. Have you get your firmware updated? Or is your router still running 1.1.3.18? Thank you!
- FURRYe38Nov 18, 2025Guru - Experienced User
Has anyone tried loading v1.1.6.36 FW? https://www.netgear.com/support/product/rax43v2
- CJ_LIUNov 18, 2025Aspirant
Hi FURRYe38, thank you for your asking. Yes, I tried the FW you mentioned, which is actually the latest version. However, it still returned the same error message: incorrect firmware.I tried updating by both integrated system setting and uploading FW downloaded from Netgear website. Neither of them worked out.
I don't know. I believe the issue has been there at least since brad99superd posted it here, but Netgear seems like not caring about it at all.
Try NMRPFlash and force v.36 on to the router?
https://github.com/jclehner/nmrpflash
