joe_wht
Aug 16, 2022Luminary
New Fiber, required to use THEIR Modem/Router
I just had 1 gig Fiber Internet installed today. ( no voice ) Last month I bought a new Netgear Modem for the fiber, but the tech said I can only use my RAX200. Their Modem> Their Router (wifi off)...
- Aug 16, 2022
You could disconnect the ISP router from the ONT. Power OFF The ONT and RAX. Connect the RAX to the ONT, power ON the ONT then power ON the RAX and see if it connects. Check the Basic tab or Advanced tab for internet status.
Aug 16, 2022Guru - Experienced User
joe_wht
Aug 17, 2022Luminary
SO EASY. Before I did anything I took a screen shot of every Their fiber router settings screens.
I went to my Netgear ReadyNAS - networking tab and changed the ip to DHCP !!
I unplugged everything, connected my RAX to their modem and *BAM* .. Everything works.
-- When the Fiber was installed and my RAX200 was feeding off Their router
I had HELL and a Half getting my NAS back online. It would not show up ANYWHERE.
Oddly.. When my router had to go through their router.. my RAX changed all it's ips to 10.0.0.1+ .. I figured it would revert back to 192. But that's perfectly fine.
Speed test was 10 MB faster than when routed through their router, and we're still in business hours. I'll check again tonight to match the prior test.
THANK YOU GUYS for your help!
-Joe
- FURRYe38Aug 17, 2022Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡 - michaelkenwardAug 17, 2022Guru - Experienced User
I thought the problem was with the network, not some added gewgaws.
Glad it worked.
