HiredGuns
Mar 31, 2023Aspirant
Nighthawk AX12 RAX120v2 firmware: v1.2.8.40 dropping connection
RAX120v2 (serial start with 6K0) constantly (at least once a day) drops the internet-connection. Wifi devices disconnect, hardwired devices loose internet connection. Both lights on top of the router...
- Mar 31, 2023
Here is a link to the latest beta firmware you may want to try it and see if it fixes your issue. https://ntgr.my.salesforce.com/sfc/p/#300000000xsV/a/8b000000lpfE/ewZuT7whqirNo5U_QG.WfrQU.h0pa5dqpbB3qz_Qi3o
HiredGuns
Did you do the factory reset as well?
Yes
I think it's a Genexis bridge, but I had no problems with a different router.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
I used the LAN cable that came with the Nighthawk.
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Auto, and several different channels, and only 2,4 or only 5Ghs
No wifi near by.
What devices do you have connected to the router?
2 laptops, 2 smartphones, xbox, satellite receiver, windows mediacenter, TV, Pioneer receiver, 2 printers, Play-Fi speakers, BBQ.
DarrenM
Mar 31, 2023Sr. NETGEAR Moderator
