jeffry01
May 02, 2021Aspirant
Nighthawk AXE11000 Tri-Band WiFi 6E Router Model RAXE500 (CM2000 or CM1200 or other)
Hello. Sorry if this has been answered before but I can;t find it on your website or in the FAQ's My ISP is Xfinity. I am using ARRIS cable modem/router combo and all works ok. I want to ...
May 02, 2021Guru - Experienced User
If the RAX has a 2.5Gb WAN Port, then the CM2000 would be a better fit as it also has a 2.5Gb WAN port. The CM1000 thru 1200 series only have 1000Mpbs ports. Though the 1200 supports LAG were the CM2000 does not as it only has 1 port.
jeffry01
Thanks
