AddisonGeek
Jul 08, 2026Aspirant
Nighthawk AXE7300 Tri-band WiFi 6E Router (RAXE290)
As I purchased the router and registered it in November 2022, how much longer is it going to be supported with firmware updates? Also, is there any possibility that open-source firmware will be allo...
schumaku
Jul 22, 2026Guru - Experienced User
This is explained up and down on the DD-WRT community: Here is no Broadcom SDK for AX SoC available, bringing a driver kit. Lack of this, you can't ever build a new Kernel....
Netgear does have released the required open source code, but without the AX SoC SDK.
