dchadduck
Sep 28, 2022Aspirant
NighthawkRAX54 not connecting after only 3 months. ???? What now??? Thanks
NighthawkRAX54 not connecting after only 3 months. ???? What now??? Thanks Tried different ports. No connection. Modem to computer works fine.
- Sep 28, 2022
Send it back.
Sep 28, 2022Guru - Experienced User
The CM is a modem only, no router here.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
dchadduck
Did all the unplugging and rebooting modem, router, computer. No luck.
- FURRYe38Sep 28, 2022Guru - Experienced User
Are there any LED indications on the top of the router?
Factory reset the router by pressing the reset button?
If nothing seems to work to correct the router, I would make contact with NG support and ask about an RMA:
- dchadduckSep 28, 2022Aspirant
Lights look normal.
Show red for 2.4 Ghz and green for 5 Ghz wifi.
Tried 3 of 4 ports. No difference.
Did all the plug and unplug routine Modem, Router and computer.
Just found the receipt. Costco. They'll take it back with no issues. Guess I order another one. Will see what they have in the store.
Send it back.
