eh12
Jan 14, 2020Star
OpenVPN Connection Issue
Wondering if someone can help ... Got a Netgear Nighthawk AX12 that I've enabled the OpenVPN server on, using the OpenVPN GUI I can connect to the network and I get a reported connection at both end...
Christian_R
Jan 16, 2020NETGEAR Employee Retired
Hi eh12,
Just curious, have you tried setting the MTU to default to see if the issue persists?
Thanks,
Christian
eh12
Jan 26, 2020Star
Christian_R wrote:Hi eh12,
Thanks,
Christian
No, because setting the MTU to default means that I have no internet, due to some weird configuration between teh RAX120 and the DM200 (both add the 8 byte headers even tho the DM200 is set to modem only mode).
Is there anyway for me to update the Open VPN settings on the router?
