ajb2
Aug 11, 2024Follower
Re: Persistent Issues with Netgear RAX43 5GHz Network and Log Settings
I am having a similar problem starting a couple of weeks ago. Everything is fine then the router stops broadcasting 5G. Reboot fixes it but it's now happening at least once per day. Firmware versi...
Aug 12, 2024Guru - Experienced User
What channel configurations are currently set on the router?
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Nighthawk-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220015/jump-to/first-unread-message
