mptan8
Oct 20, 2023Star
Re: R6700 Losing ability to connect at 2.4Ghz
I have a similar problem w my R6700AX.
but my 5G is doing well, while I keep on dropping 2.4G.
change channel did not work. channel i use has no other users @ my channel.
factor reset did...
michaelkenward
Oct 29, 2023Guru - Experienced User
mptan8 wrote:
any connection on 2.4G will lose connection - no internet.
includes computers, other cameras, and Ring Central. after I reboot router, everything works again.
then after a couple of days, 2.4G connection does not work again.
What about turning off the Ring Central. What happens then? Your answers aren't clear.
Another question fromn FURRYe38 that you haven't, as far as I can see, answered is the make and model of the modem/gateway/ONT between the router and the Internet.
This answer is important because you may well have something in there that also wants to manage the devices on your network and gets in the way of the R6700. The time lag, two days, is suspicious on that front.
mptan8
Oct 29, 2023Star
correction. Ring Camera connected to 2.4G drops off.
i have changed router security from WPA + WPA2 to just WPA2. so far has not drop 2.4G x 24 hrs.
