Redflagdan
Aug 29, 2019Tutor
RAX 120 authentication issues
For some reason after a period of several hours any device that trys to logon into my wireless system gets an authenication error, the password is invalid. My firmware is V1.0.1.90. I have tried t...
vlxiim
Jan 29, 2020Tutor
I too am having issues. My router did an auto update to the newest firmware and I'm having connection issues. I'm finding my Wi-Fi devices are connected but I have no communication or Internet. Restarting the router solves this problem. I am not happy that Netgear keep putting bugs in there firmware. Hay Netgear I thought you guys do this kind of network stuff? I going to take it off auto update and put the old hot fix back in. Get with it Netgear.
Killhippie
Jan 31, 2020Prodigy
No issues here, tbh letting it auto update is not the best thing to do, manually update then factor reset. You have to remember these are bleeding edge routers, so a factory reset is really worth it. I would suggest turning auto update off too, and check once a week manually. Also dont update using the Nighhawk app, as some have had issues that way, its best to update via the GUI though a wired connection. My routers been up since the release of 1.0.1.114 and I'm not seeing the issues you have, the only thing I can think of is I factory reset the router. Rebooting it is not enough. Hope that helps.
- Dr_ZeeApr 10, 2020AspirantUpdated to 1.0.1.118 via the app. Went well.
