Redflagdan
Aug 29, 2019Tutor
RAX 120 authentication issues
For some reason after a period of several hours any device that trys to logon into my wireless system gets an authenication error, the password is invalid. My firmware is V1.0.1.90. I have tried t...
Killhippie
Aug 12, 2020Prodigy
WPA3 has already been hacked so I would not worry to much. In fact it hacked a few times https://arstechnica.com/information-technology/2019/04/serious-flaws-leave-wpa3-vulnerable-to-hacks-that-steal-wi-fi-passwords/
Tofu-Golem
Aug 12, 2020Apprentice
Killhippie wrote:WPA3 has already been hacked so I would not worry to much. In fact it hacked a few times https://arstechnica.com/information-technology/2019/04/serious-flaws-leave-wpa3-vulnerable-to-hacks-that-steal-wi-fi-passwords/
Already? That was fast.
- avtellaAug 12, 2020Prodigy
If I recall that vulnerability was when WPA2/WPA3 mixed mode is used where attackers use a downgrade exploit.
Other exploits are there as well I think but, WPA3 is more useful when using it alone and not in a mixed WPA2/3 mode.
- TerryPhAug 12, 2020Virtuoso
I am not sure neither whether using WPA3 alone is more secure.
Already WPA2/WPA3 mixed mode was hacked by dowgrading method. Hah, it is so soon...
Wonder for a safe security , we should disable WPA3 mixed mode in the router? Something to think about.
- Tofu-GolemAug 13, 2020Apprentice
TerryPh wrote:I am not sure neither whether using WPA3 alone is more secure.
But if I disable mixed mode, my older devices won't be able to connect. Sigh.
- avtellaAug 13, 2020Prodigy
WPA3 alone is better would at least prevent a downgrade type attack, but yeah if you have older devices then that's a show stopper. I'd just use WPA2 and not worry about it.
The following support WPA3: AppleTV, iPhone 6 and newer and most Windows laptops with Intel cards I think 7265 (tested 8265 and newer) and most of the recent Android phones will work fine with WPA3 only mode. Macbooks (Tested 16") also work fine, at least the ones using the BCM436X Broadcom WiFi chipsets seen in the models from the past 5 years or so.
But yeah TVs, some smart home devices and other media gear may have issues, as they are usually not always up to spec.
