dglsmcd_USMC
Sep 28, 2020Luminary
RAX 200 New Firmware Update 1.0.2.102_1.0.56
FURRYe38 Christian_R <New firmware is found. Do you want to update the firmware? (Yes) (No)
Current GUI Language Version: 1.0.2.88_2.1.46.1
New GUI Language Version: 1.0.2.102_2.1.46.1
Current...
- Sep 29, 2020
Without the hard reset I had the same result-did a hard reset and configured from scratch (no config file used from a backup) and all is good with NTP-the router selected the correct timezone (CDT in my case) with adjustment for daylight savings time auto selected.
roger1955
Oct 30, 2020Apprentice
Only issue since installing latest F/W is, router goes into a vegetated state every 3-3 days. It just stops doing the router thingy and drops offline. Back on F/W Ver 1.0.2.8
dglsmcd_USMC
Nov 05, 2020Luminary
Firmware 1.0.2.102_1.0.56 for the RAX 200 is not the latest.
The latest can be found here:
https://kb.netgear.com/000062470/RAX200-Firmware-Version-1-0-3-102
After flashing your router please do a hard reset and install without using any saved configs (like it just came out of the box).
