BeefMaster
Feb 20, 2020Tutor
RAX-35 causing frequent disconnects with Surface Pro 5th-gen
I picked up a Nighthawk AX4 4-Sream AX3000 (model RAX35) a few weeks ago as a replacement/upgrace from a TP-Link Archer. For the most part, it's worked well, with one glaring issue - it essentially h...
Rodney1008
Apr 22, 2020Aspirant
I have exactly the same problem. I currenty have 3 other computers on my desk....two running Windows 10 and one running Windows 7 and have no problems with any of them. But the story on the Surface is completely different. After installing the new router I started to have disconnects on the Surface but not the other computers. Common sense told me that I had a computer problem. I contacted Microsoft, we made sure all the updates were done which didn't help, then we did a complete wipe and install of the operating system which didn't help. They determined I had bad hardware and did an exchange with me. I still had the problem. After a strongly worded email they offered another exchange which we did. I still had the problem with the Surface and still no problems with the other computers in the house. Now I'm rethinking all this and decided to pull the Netgear and put the TP Link back in service. Problem solved. My question is what could the Netgear router possibly be doing to cause my Surface wifi to intermittently disconnect and not cause any problems with my other computers. What is the solution? Did I just purchase a boat anchor? How about some help.
Netgear RAX-35 Router
Surface Pro 6
Marvell Avastar Wireless Network Card
Rodney
ZacharyZSun
Apr 22, 2020Guide
Still have no solution for me, but I am having a ticker open with Netgear support. I have been having continous problem on my surface pro 4 with Marvell network card running on the router. Disconnetion on both 2.4G and 5G wifi, wifi card temporarily completely gone and back only on 2.4G. I read the router log a bit, it appears my connections are mostly rejected by the router due to incorrect security and it also logged a lot of DoS Attack while connected to the router on the 5G wifi. I have no idea what caused this. But I shared my log with the support.
Also I have two TP-Link Smart Plugs. I think something is wrong with the WPA/WPA2 security on the router. Because if I only enable WPA2, when I tried to connect the smart plug with the router (failing connection all the time), the router will stop its beacon and everything connected to it will lost connection. But if I change it to WPA/WPA2, it won't bump others offline, but still failed to connect with the router.
Together with the incorrect security log of my surface pro, I suspect something is not right with the WPA/WPA2 security.
- BeefMasterApr 22, 2020Tutor
I also opened a support ticket, although so far they haven't really done anything useful (had me change the channels on my wifi signals and disable AX, neither of which made any difference).
They haven't asked for the logs yet, but I did try looking at them myself back when I first started having issues, and I noticed some of the same things you did.
I've noticed one other very weird situation. The 5GHz signal has mostly been stable in the places it reaches, with one glaring exception - my office, where the router lives. It drops CONSTANTLY in that room, four feet from the router in the utility closet. I have zero explanation for why that is happening but I essentially can't use the Surface in that room (the 2.4 drops constantly, and the 5 simply won't connect).
- ZacharyZSunApr 22, 2020Guide
My support didn't ask for the log either, but I just sent it to them anyway... I feel if I keep waiting, maybe the next wifi (wifi 7) standard will be out and running when they figure out something.
I am in a small apt and my 5G has been solid for my other devices. Maybe some other equipment in your office is interferring with it. As for surface pro, I was able to connect to 5G wifi by just keeping trying and it will connect after god knows how many attempts. Initially it says no internet, but after a bit, it will connect. Once it connects, I will be able to use it until my surface goes to sleep... And then I will try again. 2.4G is a no go to me, I feel once some internet traffic is needed, my surface will just disconnect from the router... (or the network card just crashed).
- lucaskJul 16, 2020AspirantI am still having this issue, what is the resolution? Has anyone been able to connect their surface pro consistently without BSOD?
Lucas - Rodney1008Jul 17, 2020AspirantAlthough not a good solution. I found that if I enabled a guest account, did not put any security on it, and disabled SSID broadcast to make it somewhat secure I was able to stay connected. Apparently the problem is with the security. I had another solution provided that I didn't expect. I had a lightening strike which fried the Netgear. I put the old TP Link back into use 2 weeks ago without any issues. I'll be purchasing a new TP Link.
