dlwhite66
Oct 02, 2019Guide
RAX120 slow wireless download speed (24Mbps) with High Internet Speed (325Mbps)
On Xfinity Internet Service. Using a Netgear CM1200 cable modem Nighthawk RAX120 Using Nighthawk App, Wired and Wireless connections Nighthawk App reports 326Mbps; Speedtest.Net app on wired co...
PigletRider
Nov 25, 2019Apprentice
dlwhite66 wrote:After further experimentation and several resets/reboots using latest firmware in beta V1.0.1.100
QOS on 2.4ghz = horrible performance - 1.4Mbps
QOS off 2.4 = average performance - ~24Mbps
Using an older computer with wireless card that supports 2.4 only, so could be bandlimited at the client
QOS on 5ghz = excellent performance - nearly full bandwidth of ISP, ~160-300Mbps
QOS off 5 = average performance - ~24Mbps
Using a new HP Laptop and an iPad Pro 10in (gen 6)
So something appears to be throttling bandwidth when QOS is off for 5ghz
I have no idea what is happening with QOS on for 2.4ghz. But for now I can at least rely on the 5ghz.
With default set of rules
Hmmm... I've never turned on nor toggled any of the QoS settings. When my 5GHz radio is working, I get the full speed (~200Mbps down). When it's not working, I get half of that and (or 0), causing me to reboot and/or factory reset the router, whichever recovers the radio's performance.
When I next notice a serious performance degredation on my 5GHz radio, I'll try toggling the QoS settings and see if the speed returns. If it does, then this confirms your findings. QoS ("Quality of Service" ironically), even when off, is screwing things up royally.
dlwhite66
Nov 25, 2019Guide
Don't just toggle QOS, but make sure the Mac Address of your devices is in the QOS list with priority set to Highest
- GabboCHNov 25, 2019Apprentice
Seems very similar to the issues other people have experienced on the RAX80.
I have tried the same things (QoS on/off) to try to improve 5G performance but either way it seems to grind to a halt after a day or so uptime.
Its quite clearly a firmware issue but waiting on a response/acceptance from Netgear is like watching water grind away a stone....
