DannyLin
Apr 07, 2022Apprentice
RAX120 v2 - internet connection dropped once almost every week
So I got a brand new RAX120v2 via the RMA after my RAX120 was confirmed dead. Have used the RAX120v2 for about 2 weeks and it's updated to the latest firmware. One of the issues that I observed...
Apr 07, 2022Guru - Experienced User
what adsl modem? Most are combo devices and can cause a double nat.
A double nat happens when you cascade more than 1 router.
https://kb.netgear.com/30186/What-is-Double-NAT
Fixes? There’s 3 options but only use 1.
1. Put the modem/gateway in modem only/pass through mode. This disables its routing functions.
2. Leave the modem/gateway in router mode but put the Netgears IP address into its DMZ. This forwards the data to the netgear. You can either leave the modem/gateway’s wireless enabled or disabled. Just make sure its using a different wifi channel to prevent interference
3. Put the Netgear into access point mode. This disables its routing functions. Wifi/ethernet still works but it does disable some features.
https://kb.netgear.com/26765/Which-features-are-disabled-on-my-NETGEAR-router-when-it-is-set-to-AP-Mode
DannyLin
It is an ADSL modem offered by my ISP here in Taiwan. And I’m connecting my Rax120v2 just like I connect my Rax120. So I’m sure there’s no issue with what it is connecting to.
But I’ll try the options you’ve provided. Since it drops without anything triggering it, it will be hard to reproduce. Maybe I’ll leave it there and see when it will disconnect again.
- CD_router_888Apr 13, 2022Guide
Hi DannyLin ,
你有印象你的5G channel是設定多少嗎? 有時候DFS channel可能被雷達打到而跳channel,導致wifi不穩定。
或是你可以把RAXE120v2設定成AP mode,有時候double NAT可能會有些不確定因素存在,謝謝。
- DannyLinApr 13, 2022Apprentice
Yep, I know about the 5G channel.
My current setting is 149+153(P)+157+161. I did a 5G channel scan, and not so many are in use by my neighbors. Most of them are using 2.4G.
This looks to me more of a firmware issue as there's no such issue on my previous RAX120 on 5G (set to channel 153 too).
One another very interesting thing is that my RAX120v2 is set to Region: North American, and I cannot alter this setting via the dashboard, which is weird to me.
