derekcannady
Dec 23, 2021Guide
RAX120 V2 Constant Random Reboots
The router reboots frequently sometimes every 30 minutes. I have noticed that the router reboots under heavy system load of +50% on the processor. The only way I have been able to drastically lesse...
- Jun 11, 2022Installed beta firmware 1.2.3.33 on it and then turn fan on in debug.htm. Just check mark it , don’t click on apply.
And bought a cool pad from amazon $10 . 4 days in a row no restart and router works perfect.
Laptop Cooling Pad,ESGAMING Laptop Cooling Stand Laptop Cooler 10-15.6 Inch 2 USB Ports 2 Fans with Blue LEDs https://a.co/d/dXVVnxw
Dec 08, 2021Guru - Experienced User
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapter for a period of time after the factory reset then walk thru the setup wizard and setup from scratch. Power OFF the ISP modem for 1 minute then back ON as well.
AvgNetBoi
Dec 08, 2021Tutor
How do I check that? Technican from my internet provider connected one cable from some magic box with multiple ethernet outlets to Nighthawk router and it all worked :)
- FURRYe38Dec 08, 2021Guru - Experienced User
