derekcannady
Dec 23, 2021Guide
RAX120 V2 Constant Random Reboots
The router reboots frequently sometimes every 30 minutes. I have noticed that the router reboots under heavy system load of +50% on the processor. The only way I have been able to drastically lesse...
- Jun 11, 2022Installed beta firmware 1.2.3.33 on it and then turn fan on in debug.htm. Just check mark it , don’t click on apply.
And bought a cool pad from amazon $10 . 4 days in a row no restart and router works perfect.
Laptop Cooling Pad,ESGAMING Laptop Cooling Stand Laptop Cooler 10-15.6 Inch 2 USB Ports 2 Fans with Blue LEDs https://a.co/d/dXVVnxw
Mar 25, 2022Guru - Experienced User
Ok, what channels are currently being used?
What is the transmit power set for currently? I presume 100%?
Is WMM enabled currently?
doctorcito wrote:
Hi Furry,
I did a downgrade back down to v1.2.3.28. Haven't messed around with the channel settings yet. Disabling WMM was not the solution as the router still restarted after 1 day and 6 hours. Currently at 15 hours of uptime after the downgrade and factory reset. Will keep you posted!
DarrenM
Mar 31, 2022Sr. NETGEAR Moderator
I reached out the engineering about this issue and we do have a beta firmware that may have a fix for the issue if you would like to try this firmware please send me a Pm
Thanks
DarrenM
- Zoza83Dec 06, 2021Initiate
This thing continues to reboot at random throughout the day. I prevously owned an Orbi and I'm quickly regretting spending the cash on this indadequate device. Considering the amount of $$ I hadto shell out for this, there's zero reason as to why I should have any issues with this device. What an absolute waste.
- plemansDec 06, 2021Guru - Experienced User
Did you just buy this?
Have you tried going through support?
To get a hold of support. Click on "MyNetgear" at the top.
Register an account (or login) and then the device.
From there you can start the support process. Keep in mind that its only free for the first 90 days. - derekcannadyJan 03, 2022Guide
Disable WMM on 2.4 gHZ solves reboot issues.
- BriarchildApr 02, 2022TutorHi I would like to try this beta firmware for the Rax120 reboots issue.
Could you send me an email: 75646772@qq.com - SlgreenApr 03, 2022Aspirant
Hello, can I get the RAX120 V2 beta firmware for the reboot issue? Thanks
- DarrenMApr 04, 2022Sr. NETGEAR Moderator
I have PM you the firmware.
- JayFiveAliveApr 09, 2022GuidePm sent!
- SkippyNLApr 09, 2022GuideHi moderator,
Could you please send me the beta firmware link?
Thank you in advance!
Best regards,
Skipp - doctorcitoApr 09, 2022StarBeta firmware did not do it for me. Against my own judgement, I've decided to upgrade to the RAX200 and it has been up and running for 2 days. 🤞
- SkippyNLApr 09, 2022GuideI understand your purchase decision, but you shouldnt have to buy a new (different) router ofcourse, i mean the AX 120 v2 is still pretty new and should do its job.
Having said that, i do hope you wont experience any issues! I've, in general, very good experience with nighthawk routers, so im still hoping for that definitive fix. Good luck OP - pkaytesApr 11, 2022Guide
Hi,
Can anyone tell me if the beta fw solves the inability to enable the VPN service as seen with fw 1.2.3.28?
Pete
- eksoApr 11, 2022Tutor
I am interested in the beta firmware as well.
One thing that seems to help the constant reboots was unplugging the modem from the outlet for a few seconds then plugging it again. The power source does not have a ground connection, but my apartment electric installation also doesn't have grounded outlets as well.
- SkippyNLApr 14, 2022Guide
Hi moderator,
Could you please send me the beta firmware too?
I'm currently completely unable to see my WiFi SSID, even though it's active and i'm able to connect to it through the Nighthawk app on my phone.
Thank you in advance.
Best regards,
Skippy
- LockwoodLakemanMay 09, 2022Aspirant
I am have been experiencing the RAX120 reboot issues. Can you send me the beta FW as well?
- UnKnOwN-SiAMay 09, 2022Tutor
Hi
Could you please email me the latest beta rax120 firmware.
restart and slow download speed problem
email: siavashplus@yahoo.com
thank you
- doctorcitoMay 10, 2022StarBeta version: RAX120-V1.2.3.33-0315.img. Did not solve the rebooting issue for me. Please let me know if there are any other beta firmwares I can try. Thanks!
- jcassady88May 10, 2022Aspirant
- UnKnOwN-SiAMay 13, 2022Tutor
could you please share it with me ?
rax120 beta firmware.
thank you
- UnKnOwN-SiAMay 15, 2022Tutor
Hi all
Could you please someone share the latest beta firmware for rax120 v2?
I have att fiber 5000mbps service and connect it to 5gbps rax120 port.
stability of this router is weird.
on att modem speedtest, I am getting almost 5600mbps upload and download.
on router app getting almost 4200mbps upload and download.
over wifi 6 single device I am getting 1200mbps download and 1400mb upload.
my wifi laptop card is intel wifi 6E killer 1675i(Ax211).
so please if it is possible, send me the firmware..
thank you
- plemansMay 15, 2022Guru - Experienced User
A couple things.
1. the built in speedtest on the router isn't the most accurate. we usually don't even recommend it over 500mbps because it rarely picks the best server
2. wifi isn't going to max out your connection. Or even get close. Plus AX speeds drop off quickly with distance. Not sure what link speed you're getting but actual throughput tends to be around 55-65% of what your link speed is. I've got the AX210 and on my routers, i get about the same speed as you do from wireless.
- lastate88May 15, 2022AspirantPlease send me the beta firmware.
